Differential Torque Spec's - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5344
    I've looked but can't seem to find the torque specs for a 63 differential. Anyone have them?
    What I'm looking for is:
    • Ring gear to posi. unit
    • Pinion nut on spindle flange
    • Caps
    • Cover to carrier
    • 6957
    Re: Differential Torque Spec's
    Harry, ring gear bolts are 40-60 lbs
    Preload on the pinion nut should be around 20-25 in. lbs, If you reused the old crush collar I would do 20 in. lbs.and be careful not to over torque. there is no specfic torque value on this nut, Its the rotation of the nut with a inch pounds torque wrench.(This is how to preload the bearings) any questions?
    • Harry S.
      • July 31, 2002
      • 5344
      Ed, thanks....
      • Wayne M.
        • March 1, 1980
        • 6414
        Originally posted by Harry Sadlock (38513)
        . .....torque specs for a 63 differential. ?
        • Ring gear to posi. unit (Ed answered)
        • Pinion nut on spindle flange (Ed answered)
        • Caps ____ [50-60 ft.lbs]
        • Cover to carrier _____ [35-55 ft.lbs] ....
        The last two values I filled in above are from the appendix specifications in the '63 Corvette Shop Manual.
        • Harry S.
          • July 31, 2002
          • 5344
          Thanks Wayne.....
          • Gary R.
            • April 1, 1989
            • 1806
            The 63 diff spec's are the same as all iron units 63-79. I torque new ring gear bolts to 55-60 ft. Bearing caps to 60 ft/lb using new socket heads once the caps are fit to 001 rock. Pinion drag should be set between 17-20, total drag 27-30 in/lb. Use a new crush sleeve with new bearings. If you over crush it then you have to start over. Use only a National or CR pinion seal. I use the CR's.
