Polishing Plastic (Plexiglass) - NCRS Discussion Boards
  • Theodore K.
    • December 1, 1985
    • 214
    I am restoring an older radio from a 6 volt chevy truck. The dial face is a clear plastic with lettering, etc. The surface is not too bad but needs a little polishing to remove some blemishes. I think this may have been plexiglass but I am not sure. Does anyone know some good ways to polish the surface of this piece and restore the surface. This is not a corvette piece but I suspect the material is similar to that used for instrument front covers.
    Any help is appreciated.
  • Henry F.
    • April 1, 1979
    • 68
    Re: Polishing Plastic (Plexiglass)
    You might try tooth paste or tooth power!
    Just guessing.
    Hank Fredella
    Vice Chairman Northeast Chapter
    Charter Member (1982)
    Webmaster www.necncrs.homestead.com
    • Michael H.
      • December 1, 1987
      • 730
      Meguiars makes two different polishing compounds for doing plexi-glass.
      • Chuck S.
        • April 1, 1992
        • 4668
        Just guessing.
        I would be careful about using tooth paste or powder. Both are probably pretty abrasive for polishing plastic...I doubt you'll get a good final result without resorting to finer polishes.
        Theodore, you polish plastic just like you polish paint: Start with a machine type rubbing compound (hand application, buffer not necessary). Once the big scratches are gone, progress to a polishing glaze for the finishing touch. For extremely hard plastics, like polycarbonate (Lexan), I've even used Simichrome polish with limited success, but that was a last resort.
        One caution: If the plastic is clear and flat (like a radio dial), be careful you polish it uniformly...polishing too long in one spot to remove deep scratches may cause a visible distortion
        • Patrick N.
          • March 10, 2008
          • 954
          We use this stuff all the time-http://www.novuspolish.com/
          Like others have stated, if you have any scratches you will need to remove them first with 600 grit wet sanding, then 800 grit wet sand to a dull haze. then hit it with Novus 1, 2, 3 system. You will have a perfect surface when finished.
          Be careful, corners and edges can quickly round over, use a block if it is a flat surface.
          Good luck
          Pat
          • Mike G.
            • July 31, 2002
            • 709
            anything you do will probably remove the lettering unless it on the back side.
            • Lawrence S.
              • April 1, 1993
              • 802
              I have had good luck with the Mequires product.
              • Bruce B.
                • May 31, 1996
                • 2930
                Meguires has a 3 step system which I have had good results.
                There is a cleaner (#17 ?) a polish (#10 ?) and a glaze.
                With a little elbow grease you can get excellent results.
