54 vette Hardtop - NCRS Discussion Boards
54 vette Hardtop
  • Ed P.
    • July 31, 2002
    • 270
    54 vette Hardtop
    I am looking for weather stripping for the aftermarket hardtop for a 54 vette. Any source for this, Thanks Ed
  • Mike M.
    • May 31, 1974
    • 8400
    Re: 54 vette Hardtop
    i doubt you'll find a weatherstrip set specifically molded for your aftermarket 53-55 hardtop. try the local Lowe's/Home Depot type store, check out the weatherstripping they sell for homes, pick the set closest to what you need, then head to the garage and fabricate what's needed.good luck. mike
    • Steven B.
      • June 30, 1982
      • 4000
      Ed,www.corvette-rubber.com may have bulk in usable configuration. J.C. Whitney used to as did some other auto weatherstrip companies (hemmiings.com). If not I would go with Mike's suggestion.
      Steve
      • Brett H.
        • January 1, 1996
        • 367
        I went to the local junk yard and grabbed several sets of "trunk opening" w-strip. I found one that I liked and it worked well. You need a w-strip that has a slot in it for the bottom edge of the top to fit into. The trunk application w-strip works very well.
        • Ed P.
          • July 31, 2002
          • 270
          OK thanks for all the info. That gives me a plan and some great ideas. Ed
