Original paint - NCRS Discussion Boards
Original paint
  • Rich P.
    • January 12, 2009
    • 1361
    Re: Original paint
    [quote=Wayne Womble (5569);518686]Red primer use was phased in early in 63. Generally Solid axle cars of this vintage would have had dark gray (black) primer.
    Wayne,
    thanks for the color clarification on the early cars.
    Rich
    • Jack Y.
      • June 30, 2005
      • 76
      Re: Original paint
      Wouldn't a little lacquer thinner on a rag confirm if it is lacquer or not?
      • James G.
        • May 31, 1976
        • 1556
        #18
        Re: Original paint
        My suggestion exactly. Take some lacquer thinner and rub an area like the door jamb where the hinge is. It should "easily" pull color. If enamal, it will not.
        No matter however. Enamal can look very decent rubbed out. 1000 grit and water, and then power buff with old fashion white rubbing compound will bring that car back to life, even if you remove much of the paint. The real test will be if in 4 months, the paint goes flat, and it will sooner or later, then you have to do the polish all over again.
        • Thomas H.
          • August 31, 2005
          • 1061
          #19
          Re: Original paint
          Thank you everybody for all of the info / suggestions. If/when I get a chance I'll try some lacquer thinner
          2007 Z06, Lemans Blue
