Replacing my headlight vacuum actuator for my 71 and have quick question - NCRS Discussion Boards
  • Chad E.
    • May 20, 2009
    • 21
    So I am installing the new headlight vacuum actuator and am having a problem screwing the acuator link clevis on far enough onto the end of the actuator rod. When I get to a certain point and keeping turning it starts to turn the actuator rod too. My guess is that I don't want this to happen. However, I need it to go about 1/4 further or else the linkage would be too long and the headlight would not flip down all the way.
    I saw in an old Restorer Magazine that I should hook up the vacuum line to the extend side of the actuator first. Will that keep the actuator rod from turning as I screw on the clevis?
    Anybody have direct experience with this?
    Thanks a bunch!
    Chad
    • 43279
    Re: Replacing my headlight vacuum actuator for my 71 and have quick question
    Thanks a bunch!
    Chad
    Chad-----
    The very first thing I would do is to run a bottoming tap down the threads of the clevis to make sure all the threads are clean and straight. Then, even though it's a new actuator, I would run a die on its threads. Then, with a little lube on the threads, see if you can turn it down far enough. I think you'll be able to.
    • Michael W.
      • April 1, 1997
      • 4290
      Do NOT force the clevis- there's a good chance that the inner diaphragm will tear and the actuator would become junk at that point. Chase the threads as Joe said. I hold the rod with a pair of vice grips with a piece of rubber between the jaws to avoid scratching the coating while installing the clevis.
      • Chad E.
        • May 20, 2009
        • 21
        Great advice, guys! Thanks!!
        • Chad E.
          • May 20, 2009
          • 21
          That worked perfectly!
          Thanks again!
