Term for sheet metal with stamped holes! - NCRS Discussion Boards
  • Bob B.
    • March 1, 2003
    • 831
    Hi all,
    I am trying to figure out if there is a specific term for the thin sheet metal with the stamped holes, such as that shown of the retainer for the air cleaner element in the attached pic.
    Bob
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: Term for sheet metal with stamped holes!
    McMaster-Carr calls it perforated steel sheet.
    • Tom H.
      • December 1, 1993
      • 3440
      Perforating ????
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
      • Michael W.
        • April 1, 1997
        • 4290
        If it's real, original, assembly line stuff, just call it 'expensive'.
        • Paul J.
          • September 9, 2008
          • 2091
          In the trade it's either called perforated metal or punched sheet. There may be some other names for it too.
            Another term is 'mesh'...
              Also, the term 'screen' can be applied...
              • Steve L.
                • June 30, 2001
                • 763
                Mesh and screen implies that it is made of wires in a weave pattern.
                The proper term is perforated. There are lots of suppliers that sell perforated sheetmetal with round, hex,rectangular or square holes. All in different hole to solid material ratios in 4 x 8 ft sheets.
                Steve L
                73 coupe since new
                Capital Corvette Club
                Ottawa, Canada
                • Stuart F.
                  • August 31, 1996
                  • 4676
                  If it were thicker like a block, they'd call it "pierced".
                  Stu Fox
                  • Edward B.
                    • January 1, 1988
                    • 537
                    I've always heard it referred to as "expanded metal."
                    • Ronald L.
                      • October 18, 2009
                      • 3248
                      Expanded metal mesh is what was used on the mid 70's & up air filters; thin sheet slit and roll-stretched.
                      this thin sheet with punched holes would be more consistent with punch or perf metal.
                      • Chuck S.
                        • April 1, 1992
                        • 4668
                        Originally posted by Ronald Lovelace (50931)
                        Expanded metal mesh is...thin sheet slit and roll-stretched.
                        I agree.
                        The appearance of "expanded metal" is typically that of diamond shaped openings (slits are staggered) with tiny little "twists" near the vertices.
                        Wire mesh is wires woven in a square (or diagonal) pattern with tiny blobs of weld or solder at the wire intersections. Screen is typically the same(?), but has closer wire spacing without weld or solder.
