I could use some advice and photos on R&R of roadster vent window rubber seals as well as the forward window glass run/channel (with beads & fuzzies.) Does this channel share attaching rivet points with the vertical rubber seal on the aft side of the vent frame? How does the forward/lower rubber seal attach? Can't seem to find any info in shop manual & it appears as an assembly in the AIM. I have the vent assemblies off the car & on the bench. Thanks in advance. If anyone has pics of this job, please advise.
Convertible vent window seal/wx strip
Re: Convertible vent window seal/wx strip
jeff, sorry i'm not doing a mid year now so i have no pics, however it is a very straight forward procedure, i think that if you buy the required parts first and take a look at them it will be clear as to how to go about it, if you have any ?'s at that point drop me a note and i'll walk you though it.- Top
