Various Vacumm Tubes - NCRS Discussion Boards
  • Rey S.
    • April 1, 1995
    • 277
    I must appologize, I was not descripive enough with my first post on the subject. When I made reference to"tubes" I should have said steel (bunt) tubes/pipes. There is a double pair across the fire wall that are soldered (?) together, How can I clean these things get them to look as new (at least close).
    Thanks -- Rey
    • 6958
    Re: Various Vacumm Tubes
    Ray, You can use a light steel wool to make them look new, but will remove the finish on the tubes, you will have to protect them with a little satin clear after the clenaing to dull the appearanceand keep them from rusting.
