67 Hood Release Cable - Repair? - NCRS Discussion Boards
  • Kirk M.
    • June 30, 2006
    • 1036
    Is there a way to replace the wire on a 67 hood release cable? I have my original, but the wire broke after 40+ years of use and is now too short. I can't see an easy way to remove the wire and replace it.
    Kirk
  • Ronald L.
    • October 18, 2009
    • 3248
    Re: 67 Hood Release Cable - Repair?
    Kirk, Very good question, I believe the big box cc or paragon sell the cable separate and can tell you what is involved to replace it.
    • Bill I.
      • January 29, 2008
      • 554
      Eckler's also has it. Bill
      • Gene M.
        • April 1, 1985
        • 4232
        Kirk,
        If you just need 1/4" or so you can cut back the coiled sleeve to expose the 1/4" of wire you need. If it is more than that you can not get away with this fix as the entire cable will be too short to reach it's mounting point.
        • Kirk M.
          • June 30, 2006
          • 1036
          Cable is too short to as it broke off where it mounted previously. So, I would need to replace it. It is also the cable that comes from the lever in the car, NOT the one that runs from latch to latch.
          Kirk
