Hey Guys - 71 Convertible....
I decided to re-do my brakes since I noticed that, by accident I mixed Silicone brake fluid with my Dot3. I ended up replacing the pistons and I already had sleeved calipers. I then took IPA (Isopropyl Alcohol) and ran it through the lines from the master cylinder using a vacuum pump mechanism I bought at the autoparts store. Wow. Lots of particles. I repeated this step with an air-blowing in between until I saw no particles in the IPA. I then put back the rebuilt capipers (new pistons in them) and then with them installed ran more IPA and air. Total was about 2 liters of IPA but I feel good that the lines are clean. I even replaced the front rubber lines (what the heck). I put in brake fluid and I found that priming the lines with the vacuum hand pump was not that great because air was going in through the threads of the bleeder valve due to the higher viscosity of the brake fluid.
Well - here is the question.....I had to do other weekend family activities but the car is somewhat primed with brake fluid. I pumped the brakes a few times to activate the pistons and have the brakes tighten up prior to a proper brake bleeding. However when i pumped the brake pedal a few times it got pretty hard to the point that even after being out of the car, my roters up front do not turn freely.
Is this normal????
I was going to bleed them the old fashion way with one of my kids at the pedal (rear-right, rear-left, front right, front-left). Is that OK?
Lastly, what is the cable that comes out of the proportioning valve for?
Thanks Guys!!!!
Is this normal????
Thanks Guys!!!!
