67 turn signal - NCRS Discussion Boards
67 turn signal
  • Larry S.
    • March 11, 2007
    • 457
    67 turn signal
    My 67 turn signal has a 'hair trigger', meaning if you turn on the left blinker and then turn it off, there is almost no gap until the right signal comes on. The stalk has to be precisely in the center. Many times I've thought it was off, only to look down and see the dash light blinking. How to fix?
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: 67 turn signal
    Sounds like the switch is "going south". There was a thread awhile back on switch repair. New switches are available from "SHEE-MAR"
    https://www.forums.ncrs.org/showthre...73117&uid=9106
    • Keith B.
      • December 1, 1991
      • 397
      Re: 67 turn signal
      I purchased what was told to me as the last switch from Shee Mar for 67-68. They are having an issue with the base. Something is wrong with the mold. I tried to buy a switch from Paragon and Corvette Central. They use an imported switch. Both companies have back orders. CC has 26 back ordered and 26 orders! Paragon did not expect order to be filled until mid December. Thi scould be an issue moving forward. I paid nearly double for the shee mar vs import price. There is one on Ebay currently.
      Keith Burmeister
      • Gerard F.
        • June 30, 2004
        • 3806
        Re: 67 turn signal
        Larry,
        If your signals are fuzzy, you ought to check your brake or hazard lights, they all go through the little cam on the switch.
        Take a look at this thread:
        https://www.forums.ncrs.org/showthre...witch&uid=6944
        You can replace the cam with the switch on the car.
        But---, if it doesn't work, you ought to have a replacement switch handy.
        I wasn't aware that the new Shee-Mar Switch had a defect. That one, is the third one I've had on my car. For the last year and a half, it has worked just fine.
        I think one of the problems related to replacement switches, is the screw which holds the lever onto the cam pivot. If you reuse the original screw, you'll realize that the screw is too long for the replacement switches. The aluminum pivot is just not threaded deeply enough.
        Just try a shorter screw and with a lock washer to give it some constant hold down force.
        Larry, if the signal lever is loose, and will move fore and aft, that just may be your problem. Maybe it is just a matter of tightening the lever screw.
        Jerry Fuccillo
        • Gerard F.
          • June 30, 2004
          • 3806
          Re: 67 turn signal
          Also Larry,
          It could be a matter of dirt and grease between the cam and the body of the switch.
          Jerry Fuccillo
          • Kenneth B.
            • August 31, 1984
            • 2091
            Re: 67 turn signal
            Not to hijack this but how do you fix a slow blinking one?
            KEN
            • Stephen L.
              • May 31, 1984
              • 3162
              Re: 67 turn signal
              If a new flasher didn't solve the problem, then you'll need to clean ALL the contacts in the circuits. Don't forget the ground connections thruout the car. That solved many of my dim/slow flash problems.
                Re: 67 turn signal
                The blink rate is determined by the flasher AND the lamp(s) installed. You start first with a correct factory original flasher which should be spelled out in your copy of the Judging Guide. Flashers were designed to work with a SPECIFIC lamp as different lamps have slightly different filament resistance characteristics. Do NOT be fooled by modern day 'substitute' lamps advertized as being 'compatible' with the factory originals!!!
                Then, you CONFIRM what lamps you actually have installed and compare to the lamp specs published in your copy of the owner's manual. I've seen time and time again, people ignore this aspect since the lamp came as an ASSEMBLY, fresh from GM or they installed an 'equivalent' set of lamps they bought from their FLAPS...
                One chapter member BET me I was wrong since his '63 wouldn't blink at the correct rate. Right as rain, when he went through the exercise of pulling a tail light lens and removing the lamp that was installed inside, it was NOT a correct original No. 1034...
                Once he 'gutted' the car of its existing lamps and replaced them with real McCoy 1034's, guess what? Yep, the flasher blink rate 'suddenly' became correct! I enjoyed my free lunch and beer...
                • Kenneth B.
                  • August 31, 1984
                  • 2091
                  Re: 67 turn signal
                  JACK
                  THANKS
