Comparison of Saginaw 5699250 Flex Cplg Assy - NCRS Discussion Boards
  • Jim S.
    • August 31, 2001
    • 730
    I just finished a comparison of the 5699250 Saginaw drawings of the 1967 Corvette flexible coupling assembly to a recently available aftermarket flex coupling assembly from a Corvette supplier for the same application.
    I really don't have any information as to where and how the aftermarket parts were obtained. My best guess would be that they took a Saginaw service flexible coupling assembly and had it copied.
    There are five areas that I can see that are most likely not identical to the way that Saginaw manufactured the 5699250 flex coupling in 1967. There is another area that I cannot see that I am a bit more concerned and is really more critical than the cosmetic differences.
    Let's start with the critical one first. You may have followed some of my previous rants were I expressed concerns about coupling bolts without shoulders. Most flex coupling rebuild "kits" have had common 3/8 and 5/16 bolts that merely squeeze the rubber. (All Saginaw OEM flex couplings have always had bolts that have shoulders to create a secure metal to metal connection.) With photographs of the aftermarket full assemblies you cannot determine if the two bolts are shoulder bolts or not. (I have concerns because the pictures of rebuild "kit" components from the same supplier clearly show common bolts.) You have to basically remove the bolts from a full assembly in order to determine if they are shoulder bolts or not.
    We were pretty good at Saginaw with respect to updating flex coupling assemblies to use the latest design parts. This kept our component inventory lean and prevented potential mix ups with parts that were similar but not identical. However, this meant that the 5699250 flex coupling assembly sort of evolved and was upgraded from the original 1967 design through the years. The following are just observations that I can see in the photos of the aftermarket (AM) parts:
    1. Bow tie flange - The AM flange has a cast rib that extends up the barrel of the flange. It extends up the barrel of the bow tie flange and is right next to the 12 point head of the pinch bolt. The rib was not added to the flange until 1975. In 1967 there was a small nub on top of the flange, located right in the same location as the rib.
    2. Rivet heads - The Saginaw parts had a hot upset riveting operation that quickly heated the end to a cherry red color and squeezed the end of the stop pin. That operation formed a fairly smooth rounded head. It appears to me that the AM stop pins are deformed in a press operation in the cold condition. Not a big deal except that the heads on the AM parts would have sharp edges not found in the Saginaw parts.
    3. Coupling disc - The Saginaw parts had 7 layers of neoprene rubber and cotton cloth. The layers of rubber were of the same thickness and equally spaced. The AM disc has noticeably thicker layers of rubber on the top and bottom exterior sides of the disc.
    4. Stop pins - The original 1967 Saginaw flex coupling should have had short stop pins that were 0.63 inch long. The 5699250 assembly drawing was changed in late August 1967 to a pin that was 0.81 inch long (possibly a late 1967 model year change or a 1968 start of production change.) I can't tell the length of the stop pins that are used in the AM assembly.
    5. Rubber Stop Pin Cap - I am pretty sure that the 5699250 assembly went into production with neoprene rubber stop pin caps. (They were added to the drawing in January 1966 which you might think would have made 1967 start of production in the fall of 1966.) The assembly drawing was changed in late March 1967 eliminating the caps. Now I don't know the effective date of the removal of the caps. The caps could have been eliminated as a 1968 start of production change or it could have been a running change during 1967 and the drawing was just being kept up to date.
    All of the above changes were documented in the change block on the 5699250 flex coupling assembly drawing. So any service parts manufactured at Saginaw after 1967 would have had the longer 0.81 stop pins and probably no rubber caps. Service parts after February 1971 would not have had a ground strip (they would have incorporated a coupling disc with a screen molded into one face of the disc.) Assemblies manufactured 1975 and later would have had the rib on the barrel of the bow tie flange and not the nub.
    It is possible that the NCRS studies of the 1967 & 1968 Corvettes may shed light as to when the stop pin lengths were increased from 0.61 inch to 0.81 inch. Also when were the stop pin caps eliminated? Running change during the 1967 model run, or at start of 1968 production?
    Jim
  • Jim S.
    • August 31, 2001
    • 730
    Re: Comparison of Saginaw 5699250 Flex Cplg Assy
    For anyone that missed my weekend thread. Any feedback/comments on rubber caps and short versus long rivets on 1967 flex couplings?
    Jim
    • Scott S.
      • September 11, 2009
      • 1961
      Hi Jim, glad you bumped this back up, I did miss this Thread over the weekend.
      The coupling and associated parts that I have are from a January 11, 1967 coupe, manual steering car, #07873. Build date confirmed by Trim Tag (F11), various birthday calendars based on VIN, and NCRS Shipping Data Report.
      When measuring with a caliper (digital, not the best quality), from the bottom side of the Stop Pin, through the flex coupling, to the other end of the Stop Pin, I measured a total length of 1.398 inches. From the surface of the flex coupling to the tip of the Stop Pin (difficult to measure with a caliper due edges & angles involved), I measured 0.6093 inches, definitely not 0.81, if I was measuring the correct distance.
      This January 11 car had the Rubber Stop Pin Caps. One is marked "7800470", "IPC" and "69" on the top (visible) side. The other is the same, but missing the "69", which could be worn off.
      • Jim S.
        • August 31, 2001
        • 730
        Sorry that I wasn't specific as to stop pin length. Here is a marked up photo showing the dimension on the long rivet.
        So the question becomes, "Was the 1967 flex coupling (5699250) revised during the 1967 model year or was it changed to long stop pins and the rubber caps removed for start of 1968 production.
        Obviously, the rubber caps could deteriorate and could be lost. But the stop pin length or change in length is a pretty fixed dimension and easily measured.
        Jim
        • Scott S.
          • 1961
          Jim, I updated the picture you posted of a later version steering coupler with the .61" measurement from what I believe to be the original Jan. 11, 1967 steering coupler.
            Jim -
            At what point in time did the flat at 12 o'clock on the steering gear input shaft with the gear centered begin?
              • 43248
              Jim -
              John------
              Jim will know better but I believe it occurred in very late 1969. My car was built in mid-September, 1969 and did not have the flat. Other 1969's built after mine but before the end of production in late December do have the flat. So, I think it occurred sometime during this 3 month period.
              • Jim S.
                • August 31, 2001
                • 730
                I am going to try and obtain some C2/C3 production steering gear drawings. Unfortunately, release dates and revision dates on the drawings do not indicate start of production dates. There was another system that tracked start of production dates.
                Basically, if the part number of a component did not change, it was impossible to get Chevrolet (or other GM car divisions) to track a change by revision level. If there was a new part number, there was a tracking system that kept track of the V.I.N. when the part was put into the first production vehicle. I am sure that there was a steering gear part number change when the flat was introduced on the Corvette gear sometime during the 1969 model run.
                Jim
                  Thanks, Joe & Jim.
                    • 43248
                    Jim
                    Jim------
                    Here's an interesting GM/Saginaw SERVICE kit. It contains the shoulder bolts you previously depicted + other parts. However, these bolts have the built-in "stops".
