1960 correct painting of brake back plate - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2586
    I know this has been asked and answered for a lot of different C1s but I can't fine it specific for the 58-60. The TIM & JG says "The brake backing plates are painted with a low grade gloss black paint..." It does not distinguish between the front or back side.
    I have found comments in various thread that for some models the back side of the backing plate was painted and the front side was natural metal.
    Given what the TIM & JG says for the 58-60 am I safe to paint both sides?
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
    Re: 1960 correct painting of brake back plate
    Don
    Don -
    It was painted originally with the drum in place, so the front side (inside the drum) wasn't painted; if you paint the inside, nobody but you will ever know.
    • Donald H.
      • November 2, 2009
      • 2586
      So I will not get dinged at judging? I would much prefer to paint.
      Don Harris
      • Eric E.
        • November 1, 1998
        • 254
        Re: C1 correct painting of brake back plate
        Does anyone have a good way to clean the undercoat and other junk that has adhered to the backing plates? I have tried to bead blast and wire wheel it off but it isn't working very well. I would appreciate any suggestions.
        thanks!
        • Dan D.
          • November 5, 2008
          • 1323
          I took mine to my engine machine shop and they hot tanked them. That took off all the crud. Then I sandblasted them to remove the rust and painted them. Came out real good. -Dan-
            Donald -
            Judging won't be an issue - the outer face of the backing plate can't be seen unless you remove the brake drum.
            • Donald H.
              • November 2, 2009
              • 2586
              Donald -
              Thanks John,
              That's what I needed to know.
              Don
              Don Harris
              • Eric E.
                • November 1, 1998
                • 254
                Thanks Dan,
                I also had someone recommend a radiator repair shop and use and acid tank. Looks like I will be making a few calls tomorrow.
