need a torque setting - NCRS Discussion Boards
  • Craig O.
    • July 31, 1983
    • 207
    need the torque number for the center bolt that holds the pulleys to the harmonic balancer on a 327 . I have the 3 small bolt numbers. Thanks
    • 6948
    Re: need a torque setting
    Craig, I would say the bolts should be about 35-40 ft lbs. there a 3/8 dia bolt. I don't know that they even list a spec. in the shop manuels.
      Craig -
      That's a 7/16"-20 bolt (#181629), and the torque is 60-90 ft-lbs. Shown in your Assembly Manual in Section L79, L76, or L84.
        • 6948
        John, I read the post wrong, your correct. I thought he was talking about the pulley bolts.
        • Craig O.
          • July 31, 1983
          • 207
          ah, I see it thanks John
