Drum brake shoe springs - NCRS Discussion Boards
  • Steve W.
    • January 1, 1990
    • 34
    I'm putting new brake shoes on the 62 next week. Thought I would try to find new hold down springs since the old ones have been on there for at least 20 years. My FLAP (O'Reillys) has the spring kit for a 63. Are the 63 springs any different from a 62?
    • 43247
    Re: Drum brake shoe springs
    Steve------
    If you're referring to a brake shoe hold-down pin and spring kit, it should be the same for any drum brake-equipped Corvette. If, by chance, you are referring to any of the other springs (parking brake adjusting, etc.), those are different for C1 and C2 Corvettes.
    • Steve W.
      • January 1, 1990
      • 34
      Yea, I just need the springs that connect the shoes to the pin. I'm also gonna try to install the self adjusting kit. Thanks Joe. Steve
      • Stuart F.
        • August 31, 1996
        • 4676
        The front shoes on the 63 - 65 are wider. I don't know about the springs, but the pins are longer. Ran into this with Rob M. and sent him some I had from a kit.
        Stu Fox
          • 43247
          Stu Fox
          Stu------
          The kits usually come with both length pins.
