C1 third arm bearing - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2580
    Does anyone have an easy way to get the third arm bearing out. I have an article from a Summer 1992 edition, but the parts for the tool he used are not easy to find.
    Anyone else with a way to get it out?
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Jerry W.
    • January 27, 2009
    • 588
    Re: C1 third arm bearing
    Third arm bearing removal....from Rich M. 59 restoration
    http://home.comcast.net/~richmz/site/?/page/1959_Corvette_Restoration_Project/
    • Dennis C.
      • June 30, 2002
      • 884
      Don,
      Besides Rich's excellent post, here is a link to Rare Corvette's How To Articles.There is an article there on third arm bearing removal and a whole lot more.
      When I did mine earlier this summer, nothing would get the bearing moving.I ended up purchasing a nut to fit the stud from McMaster Carr and after threading it on the stud, clamping the nut in a vise. I then used a hammer and block of hard wood all around the housing until there was movement. After that I had no further problems with removal.
      Dennis
      • Donald H.
        • November 2, 2009
        • 2580
        I did find and order nuts and a bolt with correct threads from boltdepot.com and will try the vice approach first.
        Don
        Don Harris
        • Dennis C.
          • June 30, 2002
          • 884
          Don,
          It can't hurt to soak it in penetrating oil first. I like Kroil's but there are others.
          Dennis
          • Ray C.
            • June 30, 2001
            • 1132
            Don
            Hi! Donald
            I made this bearing puller for the third arm bearing. It helps if you soak the bearing in penetrating oil. Email me, ray63@rochester.rr.com , with your address if you would like to borrow the puller. I will send it to you.
            Ray
            Ray Carney
            1961 Sateen Silver 270-HP
            1961 Fawn Beige 315-HP
            • Donald H.
              • November 2, 2009
              • 2580
              Now that I have the bearing out, thanks to Ray Carney and his tool, do I pack the new bearing with bearing grease when I install?
              Don Harris
              • Tom P.
                • April 1, 1980
                • 1814
                Not if the new bearing has a seal on BOTH sides.
                • Donald H.
                  • November 2, 2009
                  • 2580
                  Third arm paint or natural?
                  One more question. My 1960 AIM is pretty clear for what get painted and not as far as the front suspension, but I don't find anything on the third arm whether it is painted or natural?
                  Don
                  Don Harris
