Bolt identification, please? - NCRS Discussion Boards
  • Scott S.
    • September 11, 2009
    • 1961
    Most of my fasteners are in labeled bags, but I have a few that ended up in the "unknown" bag. These have the "RSC" headmark, no grade lines, looks like a #18 thread pitch (that may not be the correct terminology), the shank is 5/16" diameter, and from the underside of the head to the flat tip of the shank is 3/4".
    I have six of them, but they may be part of a larger group, so the quantity may not be significant.
  • Ronald L.
    • October 18, 2009
    • 3248
    Re: Bolt identification, please?
    Scott, what year? Look like fan shroud attach for 66-67
    • Scott S.
      • 1961
      Hi Ron,
      The car is a 1967 coupe, L79 with C60.
      • Ronald L.
        • October 18, 2009
        • 3248
        Hi Scott, I saw that later on, if you are not using these I need some of this exact part...
        • Scott S.
          • 1961
          If I have any of these left over once the car is back together, you may have them. I'll keep an eye out for them in my regular bolt-searches, too.
          • Dan H.
            • July 31, 1977
            • 1372
            One possibility is that they are pn 122007 bolts, 8 of them were used to secure the rear muffler hanger to the frame and muffler. (assuming it's under car system).
            Dan
            1964 Red FI Coupe, DUNTOV '09
            • Ronald L.
              • October 18, 2009
              • 3248
              That is the correct part, correct for 66 67 in about 10 places.
              • Rich P.
                • January 12, 2009
                • 1361
                Off hand several applicatins come to mind.
                the 2 already mentioned are correct. The others are for muncie side cover to main case bolts, headlight support rods upper bolts, crank case breather tube to intake
                • Scott S.
                  • 1961
                  Thanks Ron, Dan and Rich, much appreciated!
                  • Peter L.
                    • May 31, 1983
                    • 1930
                    Check usage on attachment of the sb C60 Fan Shroud ring. Pete
