Hi all,
I am replacing my master cylinder this weekend with a correct 509 redone by WhitePost. I removed the black paint from the machined areas by the brake lines, as well as removed the paint from the front DC pad.
However, is there a way to tell what kind of brake fluid my car has in it currently? I obviously want to fill the system when I bleed it with the same type of fluid that's in there now, but I do not know how to tell the difference between Dot 3,4,5..
I am not sure if one type is compatible with another type (meaning adding DOT 5 to my system that already has DOT 4 in it for example). I just don't want to screw it up (as I'm good at) so any advice is always appreciated.
Thanks in advance!!!
ARA
ARA
