I seem to remember that in '57 Chevrolets you could pull the ignition key from the ignition switch/lock cylinder even with the engine running. Off hand, I am not sure as to why they allowed this. I had a new 1965 Chevrolet and I think that on that car you could not pull the key with the engine running.
I also know for sure that the lock cylinder that was built into the head of the Saginaw locking steering columns starting in 1969 only allowed the key to be removed in the OFF-LOCK position.
Does anybody know if and when the indash lock cylinders were revised so that you could not remove the key in the RUN position?
Jim
Jim
. Chip.
