A Milestone? - NCRS Discussion Boards
A Milestone?
    • 43271
    A Milestone?
    Well, this should be my 25,000th post to the board. I was wondering what my first post to the board was. So, I checked the archives. As far as I can tell, this was it:
    August 8th, 1998, 11:28 AM
    Joe Lucia (12484)
    Re: Back-firing LT1!!!!
    re back firing lt joe lucia another possibility is a defective a i r diverter valve you can check for this by removing the belt from the pump and disconnecting the vacuum line which provides the vacuum signal to the valve from the carburetor if this resolves the backfire problem you've found the cause another possibility is a defective ignition coil
  • Michael W.
    • April 1, 1997
    • 4290
    Re: A Milestone?
    Yup, 25K. Congratulations and thanks for all the help and advise over the years.
    • Kenneth T.
      • March 23, 2008
      • 631
      Re: A Milestone?
      Joe,
      25K! Think of all the knowledge and information you have provided to the NCRS members who seek help with their cars.
      I remember GM had a "Spirit of America" theme, You are truly the "Spirit of the NCRS" Thanks for all your help and support.
      Ken
      • Gary J.
        • April 1, 1980
        • 1246
        Re: A Milestone?
        That is a lot of posts Joe, but you have help us out a bunch. Just think if you had a dime for every part # you have referenced over the years. I would hate to be keeping track of that record.
        • Steve M.
          • October 22, 2006
          • 88
          Re: A Milestone?
          Thanks for all of the knowledge you have shared on the board Joe. Not only have I learned things from your posts in the archives, but you have been kind enough over the past few years to answer some questions I have sent to you privately. Many thanks!
          • Jerry W.
            • January 27, 2009
            • 588
            Re: A Milestone?
            AWESOME.....AWESOME......You should write a book....Thanks Joe
              • 15630
              Re: A Milestone?
              ongratulations Joe. You have set an amazing record.
                • 11692
                Re: A Milestone?
                Congrats Joe!
                I doubt that it will be equalled, especially on a "per year" basis.
                You made me check - my first I can find was Jan 12, 1999.
                • Larry M.
                  • January 1, 1992
                  • 2701
                  Re: A Milestone?
                  Joe:
                  THANK YOU for your help and guidance over the years. I certainly learned a lot from you, and I'm sure that applies to many others on this forum as well. Continue to help us out........
                  Larry
                  • Michael G.
                    • November 12, 2008
                    • 2158
                    Re: A Milestone?
                    Joe,
                    Thanks for all your advice and input. Its nice to have someone on board who is always informative, knowledgable, and well written.
                    Hope your mouse hand holds up for your next 25K.
                    Mike
                    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
                    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
                    • Dan M.
                      • March 6, 2009
                      • 157
                      Re: A Milestone?
                      Joe
                      Wow! Quite a milestone. Thanks so much for all the help in the Technical Discussion arena. Nice to have some know-it-alls around that don't act like the classic know-it-all.
                      Thanks Joe
                      • Loren L.
                        • April 30, 1976
                        • 4104
                        Re: A Milestone?
                        Joe, your quality answers, responses & clarifications are worthy of the utmost respect and appreciation.
                        For those of us who have been around too long, our "Milestones" are Howard Kirsch lending the $$$ to publish the Restorer, John Amgwert's dedication to information that had never been published before and attesting to its accuracy and the leadership of Bill Clupper in the years when NCRS could very well have vanished from the scene, followed by the knowledgable, on all levels (with the possible exception of RR -watch, he'll go buy one) of Mike McCagh. It became Nirvana for car clubs, but the failure to comminicate with members-at-large is diminishing its luster on all levels.
                        As a member from Texas once expressed, "If you membership # is above 5000, you have no idea what this club went through to survive.". But fortunately it is probably still the best club on the planet.
                        • Jim C.
                          • April 1, 2006
                          • 290
                          Re: A Milestone?
                          Wow!!!! Well done Joe!!!
                          • Scott S.
                            • September 11, 2009
                            • 1961
                            Re: A Milestone?
                            Everybody says the first 25,000 are the hardest
                            Thanks for all your help Joe, here's to your next 25K,
                            Scott
                            • Paul Y.
                              • September 30, 1982
                              • 570
                              Re: A Milestone?
                              Thanks Joe. Thats only 5 or 6 a day depending on what day it is. What? You want Christmas off and some time to get some Maine Lobster? Ok. As long as you make it up. I am learning from you every day and I humbly thank you. Paul
                              It's a good life!
