Windshield installation - NCRS Discussion Boards
  • Rich G.
    • January 9, 2009
    • 51
    Is the windshield put in with the ribbon sealer or the urethane sealer? I was talking to a glass shop and he said the ribbon type is for cars from the 60's. I thought it was the ribbon type and I see they show the ribbon in the parts catalogs for these cars also. ??? Thanks.
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: Windshield installation
    Urethane in caulking gun tubes. If your parts catalogs show the ribbon sealer for front windshields, those catalogs must be out of date. (And your glass man, too, for that matter. )
    I don't believe butyl ribbon sealer even meets Federal safety guidelines for front windshields anymore. I asked this question a few years back, and seem to recall that was John Hinckley's explanation. Try search.
      Rich -
      GM never used the butyl tape (ribbon) adhesive for windshield installation, nor did they release it for Service use - they released a "Kit, Windshield Caulking", which contained the silane primers for the body opening flange and for the glass, and the Thiokol adhesive.
      Some glass shops like to use the 3M butyl tape (because it's easier and cheaper), but it's technically illegal to do so; GM cars were certified to the windshield retention requirements of MVSS 208 with Thiokol adhesive, long-since replaced by urethane windshield adhesive. Any ethical glass shop worth their salt wouldn't use the 3M butyl tape on a GM car.
      • Steve L.
        • June 30, 2001
        • 763
        When I took delivery of my brand new 73, there was a great big blob of black adhesive about 2 inches high and 3 inches wide at the bottom of the front windshield just above the dash. It definitely was not a ribbon. The guy installing must have sneezed when he was applying the adhesive.
        I cut it off myself thinking it was easier than taking it back to the dealer. But I should have taken it back since it took me a long time and a lot of effort to cut it out.
        You'd think someone would have caught that at the plant and cut it out themselves.
        Steve L
        73 coupe since new
        Capital Corvette Club
        Ottawa, Canada
        • Wayne W.
          • April 30, 1982
          • 3605
          Rich -
          John,
          I agree that they didn't use the same butyl tape commonly sold at parts stores, but that stuff they did use wasn't just applied out of a gun either. The originals were definitely some kind of preset material, because you can see the backing on originals, and there was no spacers to hold the thickness, except at the bottom to keep it from sliding.
          • Steve L.
            • June 30, 2001
            • 763
            Wayne,
            I would have thought they did apply it by hand from some kind of hadn held dispenser because I had a big bloob of it as I posted previously.
            Steve L
            73 coupe since new
            Ottawa, Canada
              • 15640
              Just a guess, since I wasn't there -- but I would expect they used a hand held gun that connected to a drum with a pump that pumped the adhesive into the gun and onto the windshield as the operator triggered the gun. The cloth ribbon, or dam, was applied to the windshield first to contain the spreading adhesive.
                • 3422
                Hi,
                I ask this question each time a 70-72 windshield installation thread is started. Has anyone seen a damming strip that's still available and resembles the original?
                  Hi,
                  What appears to be a "ribbon" on original windshield installations is the fabric-backed "dam"; it was extruded onto the fabric when it was made (to maintain its shape while on a spool), and hot glue was applied to the fabric when it was installed on the windshield.
                  Local glass shops should have several varieties of the extruded dam material; I just had the windshield replaced on my 2010 Dodge Avenger, and our local glass shop had three different cross-sections of the dam material. If you can't find it at a glass shop, any Toyota dealership will have it.
                    • 15640
                    Hi,
                    I thought I saw a response from someone to one of your previous posts which suggested a Toyota product.
                    • Rich G.
                      • January 9, 2009
                      • 51
                      Thanks all for the info. I'll go with the urethane. Actually they do list the ribbon in the Ecklers website. Part # 20361 You would think they"d list the correct stuff.
                        • 15640
                        Actually I would think they would list what sells.
                        • Steve L.
                          • June 30, 2001
                          • 763
                          I've asked this before but I'll try again. Anyone have a part number for the Toyota dam?
                          Steve L
                          73 coupe since new
                          Ottawa, Canada
                          • Chuck S.
                            • April 1, 1992
                            • 4668
                            Knowing how you guys loathe searching the archives, here's a beginning to more info on Alan Struck's windshield install. https://www.forums.ncrs.org/showthre...oyota&uid=4611
                            The interesting thing is...all I needed to do was type "Wi...", and the search window populated itself with "windshield dam TOYOTA" (I am not making this up...if searching the archives gets any easier, the software will be reading our mind. ). There's seven threads including this one.
                            The bad news...there ain't no Toyota part number given that I saw, and there's probably a dozen such numbers anyway. What I would do: Walk around mall parking lots looking in Toyotas until I found a dam config closest the the original C3 dam, write down the Toyota's VIN (no parts without a VIN), and visit the nearest Toyota dealer. HOWEVER...watch out for mall security; they might think you're trying to boost a Toyota (And...better have a good story ready; they'd never believe the truth.)
                              • 3422
                              Hi,
                              I used the Toyota damming strip because it was the closest I could find. BUT it's really not very much like the original in cross section. I have some very nice small examples (with fabric as John mentioned) I was able to save from my original, but can't find anything close with the fabric on the market.
                              I'd heard that a knowledgable member restoring a 70 LT-1, a few years ago, was trying to duplicate the fabric but don't know where that might have lead since I never got a look at the completed windshield installation.
                              Still looking!
                              Here are 2 pictures I've retrieved from earlier posts. The foto shows the Toyota strip, its a damming strip and about the right size, but not very close to the original.
