Another '68 Question - NCRS Discussion Boards
  • Brian W.
    • September 30, 1990
    • 216
    I have two sets of front spare tire mount tray bolts, one set is 6" long and the other set is 6 5/8" long. Can anyone tell me if one set is correct for '68 and if not, what do I have? Thanks
    Brian
    • 43246
    Re: Another '68 Question
    Brian
    Brian------
    Are you measuring the bolts TOTAL length from the top of the head to the bottom of the threads (as shown in first attached photo) or are you measuring the length from the base of the head to the bottom of the threads (as shown in the second photo)? Also, are both sets of bolts configured as in the attached photo?
    • Brian W.
      • 216
      Joe:
      Yes the bolts look exactly like the ones you show. I measured the TOTAL length and the long one measures the same as the one you show. If I measure the other way, the long ones are 6 1/4" and the short ones are
      5 3/4".
        • 43246
        Joe:
        5 3/4".
        Brian------
        The shorter ones are the ones you need for a 1968. Many think that the 1968-82 bolts were all the same. However, they were not. The 1968 bolts were GM #3929208 and were about an inch shorter than the 1969 and later bolts, GM #3956389. The GM #3929208 bolts were discontinued from SERVICE in July, 1972 and replaced by the 3956389.
          • 43246
          Joe:
          5 3/4".
          Brian------
          Also, would you please check one other thing for me? Please measure the length of the 1968 (short) bolt from the base of the head to the end of the un-threaded shank portion (i.e. the point where the nut seats against the shank of the bolt). This is shown as dimension "A" in the attached photo. Also, please measure the length from the top of the head to the end of the un-threaded shank. This is shown as dimension "B" in the attached photo.
          • Grant W.
            • December 1, 1987
            • 407
            Oh Crap now to look for a set of 68 tire bucket bolts. Measuring as in your Pic "B" I get a measurement of 4.75 inches.
            Joe would you know what these are for. On the end of the bolt is a backward S.
            Thanks, Grant
            • Grant W.
              • December 1, 1987
              • 407
              Thanks, Grant
              pushed the wrong button but here is the posted picture.
                • 43246
                Grant------
                These appear to me to be GM #3956389 bolts used for 1969-82.
                • Brian W.
                  • 216
                  Joe:
                  Measurement "A" is 4" and measurement "B" is 4 5/8".
                    • 43246
                    Joe:
                    Brian------
                    Excellent. Thanks. I was not sure of the exact dimensions of the 1968 bolts. Now, I am.
