Re: L1969 to E 1970 Big Block Dipstick
Don-------
If it's 19" from the top of the "bell" to the "add" mark, then it could very well be the 3959158 "mystery dipstick". I don't know of any other big block dipsticks, Corvette or otherwise, that had this dimension. Of course, it's also possible that some other measuring convention was used for the 3959158 dipstick (e.g. from the seat to the "add" mark) and that would throw a "monkey wrench" into the whole process here. However, assuming that the 3959158 uses the same convention for dimensions as other big block dipsticks, this would be the only one with a 19" dimension from the top of the bell to the "add" mark.
I hope you get your camera back soon because I would really like to see photos of this dipstick.
Also, please check the entire length and both sides of the blade very carefully for a stamped part number. While some dipsticks had no part number stamped on them, many did. It may be much further up the blade from the "full" and "add" marks and it might be VERY lightly stamped.
Don-------
