Has anyone had experience with America's Finest Corvettes' 1963-1983 upper & lower ball joints from both a judging and driving performance perspective?
Pete
Pete
) drilled for rivets or bolts? The OEM ball studs have smaller holes for the rivet, which when headed expands on the diameter of the shaft to fill the holes in the control arm and ball stud. In general replacement ball studs are produced with a slightly larger hole so a screw can be installed. If riveted it is questionable if the rivet shaft will expand to fill this larger hole, and it probably will not expand properly if the hole in the control arm is the smaller diameter and the ball stud hole is the larger diameter.
