Zerex G-05 - NCRS Discussion Boards
Zerex G-05
  • Dick W.
    • 10483
    Re: Zerex G-05
    Originally posted by Ray Geiger (9992)
    Hello;
    Does a rarely driven 60s Corvette(5 miles a year) engine w/ conventional ethelyene glycol require changing every two years or will adding cooling system conditioner suffice?
    Thanks.
    I would buy the reagent test strips from Wix, NAPA, Carquest and test the coolant. The strips will show you the PH, additive level, and freeze protection level. I have run antifreeze 10 years using the additive with no problems. This is a very common practice in large fleets also
    Dick Whittington
    • Michael J.
      • January 27, 2009
      • 7141
      Re: Zerex G-05
      That's a good idea. I doubt cars that sit for the majority of their time, in a garage, would need very frequent changes. Is it just time or "heat&wear" time that breaks down the additives?
      • Ronald L.
        • October 18, 2009
        • 3248
        #18
        Re: Zerex G-05
        Michael, This entirely depends upon the condition of your cooling passages of the block, and all external components.
        • Dick W.
          • 10483
          #19
          Re: Zerex G-05
          Hello;
          Thanks.
          Dick Whittington
          • Jeff P.
            • 799
            #20
            Re: Zerex G-05
            What would be a reccomended flush additive ? I'm doing the same to my L79 now. Thanks, Jeff
            68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
            2014 Arctic White Z51 Vert. (Wifes)
            • Michael J.
              • January 27, 2009
              • 7141
              #21
              Re: Zerex G-05
              I used the Prestone Radiator Flush, in the small yellow plastic jug. It seemed to work fine.
                • 15610
                #22
                Re: Zerex G-05
                I like RMI-25. I get it on-line. You might want to Google it.
                • Ara G.
                  • January 31, 2008
                  • 1108
                  #23
                  Re: Zerex G-05
                  Mike,
                  I recently replaced my radiator with a new Dewitts one (you were nice enough to post a reply to my post and had some great suggestions for me when it came to turning the radiator before removing it). I read the archive posts on Zerex and called the company and spoke with an engineer to make sure it was compatible and would "mix" with any remaining green antifreeze in my engine. They said it will be fine and will mix fine. I simply mixed a couple of gallons of it with distilled water in a 50/50 combo and poured it in. Good luck with your project...Regards
                  ARA
                  • Michael J.
                    • January 27, 2009
                    • 7141
                    #24
                    Re: Zerex G-05
                    Originally posted by Ara Gechijian (48542)
                    Mike,
                    ARA
                    Great! I also had some left over DexCool orange stuff in my engine, as I didn't want to go to the hassle of removing the drain plugs, but yes that is OK. Glad yours is moving along, I'm now dealing with the radio and speaker .
