Help! on 57 distributor - NCRS Discussion Boards
  • Mike Z.
    • 226
    I am rebuilding a distributor out of a 57 with 2 X 4 carbs P/N#1110891. I pulled it apart and not surprising, it needs a mainshaft and lower bushing.
    I have checked what I consider all the normal sources and googled until my eyes crossed-no mainshaft. Can anyone give me a source to buy a new shaft?
    Also, the adjustable mechanical advance set-up. Although, the adjusting nuts are held in a captured lock, they are not adjusted in the same position within the slots. Does anyone have any info on how to adjust? I have a Sun Distributor testor, but none of my books have this P/N for the advance mapping, so any info would help.
    Any help is greatly appreciated.
    Mike Zamora
    #12455
    Re: Help! on 57 distributor
    Mike -
    Have you tried Grossmueller's and Mary Jo Rohner?
    The 891 centrifugal advance map (crankshaft degrees and rpm) is:
    1* - 5* at 800 rpm
    19* - 23* at 2600 rpm
    26* -30* at 3700 rpm
    • William C.
      • May 31, 1975
      • 6037
      Mike, there is an 891 distributor on the flea right now, two days left, might be worth a look if the parts are good. The shaft is part number 1935503 (group 2.372) same part used in dist #1110872, and 1110879.
      Bill Clupper #618
      • Mike Z.
        • 226
        Thanks, guys:
        John that is exactly what I needed for the advance mapping-Thanks.
        Bill, thanks for your help. Actually found a good used shaft from Al @ Chicago Corvette for what I thought was cheap.
        So, with both your help, I can fix this customer up with a ReNued distributor for happy motoring of his dream Vette.
        Mike Zamora
        #12455
