Stock looking BB exhaust gaskets and paint - NCRS Discussion Boards
  • Domenic T.
    • January 28, 2010
    • 2452
    Where can I get the right gaskets for my 67 BB? I have a set of fel-pro gaskets that are un-opened . They were for the cast manifolds but look like header gaskets.
    I am going to coat the manifolds after bead blasting. I know that ruffels a few feathers but can any one recomend a good coating or high temp paint?
    The guy at Allens exhaust says that there is a powder coating that looks good also.
    DOM
    • January 31, 1988
    • 43194
    Re: Stock looking BB exhaust gaskets and paint
    DOM
    DOM------
    Gaskets between the exhaust manifolds and heads were NEVER originally used on a Corvette big block. In fact, they were never originally used on a small block, either, except when they went to tubular type manifolds for the 1980 model year for LG4 applications.
    If you want some anyway, they are usually supplied in rebuilder-type gasket sets. You might even be able to purchase them individually at auto parts stores.
    Some 8.1L truck applications of the 2,000's used a multi layer steel exhaust manifold gasket. These will work on 65-74 Corvette applications with very slight modifications if one desires a gasket.
    • Domenic T.
      • January 28, 2010
      • 2452
      Joe,
      Now that you mention it I am trying to think back to the early days.
      I stone blocked my surfaces and they are true.
      I don't want gaskets if they were not there in the first place.
      I would like to sneak a sealer in that I can wipe off after installation.
      Red RTV? what do you think?
      DOM
        • November 30, 1989
        • 11611
        I'd use nothing.
        Be sure your exhaust manifolds are trued, and install using new bolts, torqued to spec. Don't forget the proper french locks so the end bolts don't wiggle out. Then, drive it and don't worry - it won't leak.
        Patrick
          • January 31, 1988
          • 43194
          I'd use nothing.
          Patrick
          Patrick and Dom------
          I agree.
          The reason for new bolts is that these things get continuously "heat treated" and end up so hard "through-and-through" that they are brittle and can break. Always use new bolts on the exhaust manifold
          • Domenic T.
            • January 28, 2010
            • 2452
            Thanks guys,
            I have new bolts and SS french locks. I'm going to coat them with something that will stop them from rusting, even at the expence of points.
            Any recomends. The stuff I used was 25+ and not that good.
            DOM
              • January 31, 1988
              • 43194
              Thanks guys,
              DOM
              DOM------
              You could use VHT VERY HIGH HEAT black. However, these bolts have a black phosphate finish. They do rust a little over time but it's not really too bad. I'd leave them as-is.
              • Domenic T.
                • January 28, 2010
                • 2452
                Joe,
                I meant to say the manifolds that I beed blasted. Thats what I want to coat.
                DOM
                  • November 30, 1989
                  • 11611
                  Thanks guys,
                  DOM
                  The only way I know is to send them to Jerry MacNeish, have them coated, and then spray them with the paint he provides. Not exactly as-factory, but they will never, ever rust.
                  Any other coating will either rub off, rust, or look like you used cheap brush-on paint.
                    • January 31, 1988
                    • 43194
                    Yes, that's what I recommend, too, and what I do. After the manifolds are heat-cured they appear very close to natural cast iron and no rust ever.
                    You can also use the VHT Very High Heat cast iron paint without the pre-coating but I don't think it will be as durable. Plus, there's another advantage to the process used by Jerry M. The pre-coating used is very "porous". The paint "soaks into" the coating and makes for a very natural cast iron appearance. It does not appear like a finish which "smooths out" the cast iron and looks obviously painted.
                      • 15575
                      DOM------
                      Didn't the LT1 of 1992 to 1996 have gaskets at the exhaust manifold? It did in the B & D-body application, but those have iron heads.
                      • Domenic T.
                        • January 28, 2010
                        • 2452
                        Thanks guys,
                        I think thats the way to go.
                        Patrick, that site shows it all.
                        DOM
                          • January 31, 1988
                          • 43194
                          Terry------
                          Yes, 1992-96 LT-1 and LT-4 did use exhaust manifold gaskets. As a matter of fact, 1984-91 small block apparently did, too, but I'm not 100% sure of that. I should have further qualified my previous response by stating no 1955-82 Corvette V-8 used exhaust manifold gaskets except those 1980-82 with tubular manifolds.
                          • Rich P.
                            • January 11, 2009
                            • 1361
                            On BB exhaust manifolds I have ALWAYS used RTV High Heat Copper. and I paint the heads with the machined surface exposed for extra squish when I bolt on the manifolds. I have never had a leak or problem in over 20 plus years of doing this.
                            I spread the thinnest coat of sealer close to the inner opening so when you tighten the manifold down you get minimal or no sealer squishing out.
                            I also like to get the manifolds ceramic coated inside and out to, 1 help keep a nice look but more importantly 2 keep heat down.
