I have a '67 L-79 with 52,000 miles, engines never been apart. I have had a metallic grinding sound at idle at the front of the engine for some time. Thought it was water pump or alternator bearings. Took things out of the system one by one this weekend and determined it must be the timing chain. Dropped pan, timing chain cover etc and sure enough I've got about one inch of play on the slack side of the timing chain; it was hitting the cover in two places. I am surprised it has stretched at only 52,000 miles (I know mileage is correct); after 43 years GM probably won't honor a warranty claim...
Any recommendations on sourcing a replacement chain and timing gear? I am told the original has nylon in the timing gear and replacement can be bought from GM but is expensive. Also that aftermarket sets are available with steel gears; those are more durable but are noisy. Durability isn't really an issue given the few miles I drive it. I would like to keep the engine stock as I may show the car and like originality.
If anyone has recently replace a chain and has a recommendation (or warning) please let me know. Thanks, JimB
