Need a second opinion.
Motor was overhauled about a year and half ago. Stock stuff, new everything except castings. This includes guides, valves and seals. Iron guides but I'm not sure what the seals are (last two pics are of the seals). Engine has about 800 miles and has not stopped using oil. About a quart per 300 I'd say. No noticeable smoke when driving and none on start-up. Engine was OH'd before I purchased the car, shop didn't log the type of stem seals on the invoices I have. They are 6 states away.
I brought home a bore-scope from my maintenance department (not automotive maintenance) to look inside the intake runners hoping to find oil in them. No such luck. So went on and stuck the camera down in the heads to peek at the intake valves and this is what I found. My hope is this burned oil buildup is not bad enough to warrant removing the heads and I can just replace the seals, IF that's the problem. What thinks you??
Also took a shot of the #1 piston crown and also the "seals" on the valve stems. My feeling is the engine shop installed some kind of high-tech seal that either doesn't work properly or was improperly installed. I haven't built an engine in over 25 years, so I either don't recognize these seals or forgot that I should recognize them : ). I suppose we can still get the umbrella style that GM used? If so, who makes the best, highest quality umbrella?
These are from 4 different cylinders. All other intakes look essentially the same.
The guide seals.
#1 Piston crown
The guide seals.
#1 Piston crown
