I have checked the archives and see many problems with closing cycling etc but nothing that has helped me so far.
My headlights open and close with authority, no problem. (with the headlight switch and stem valve)
My wiper door will not open with the dash switch or stem valve at the steering column.
I replaced the interlock switch when I found the button broken off. I have vacuum, via the steel line from the drivers side to the hose and on the middle (red) orifice of the interlock. I have vacuum to the lower orifice, white.
If I open the door by hand and push in the stem on the valve under the steering column the door closes nicely. The actuator is good it, it will open and close the door with my blowing or sucking on the hose.
Thanks Ed, that is where I am going now.
The vacuum relay valve is my next test.
Ken
Ken
