C-3 Frame Paint - 1970 - NCRS Discussion Boards
  • Clark E.
    • March 1, 1991
    • 163
    I'm considering using Eastwood Extreme Chassis Black (satin finish - 60-70% gloss) over an epoxy primer for the finish coat but have read complaints on their website about an extensive drying time. I'd appreciate comments from anyone that has used this product or can recommend an alternative paint. Thanks...Clark Erlandson 18941
  • Paul S.
    • June 30, 1982
    • 359
    Re: C-3 Frame Paint - 1970
    HAVEN'T USED THIER PAINT. THIS IS WHAT I USE , IT'S BULLITT PROOF , ONLY DRAW BACK IS DRY TIME.
    Dupont Industrial Coatings Product No. 45-1640 Imeron 3.5ST Satin Black, Two Part Poly Urethane.
      • 3416
      Hi Clark,
      It's good to see you on the TDB.
      Besides the replies you get from this thread, you may want to take a look at Joe Rueda's thread...'Judging mid year frame finish'... presently on the second page. I don't know if you've seen it, and think some of the information may be interesting to you too.
      Good Luck!
        • 15621
        With any kind of luck he will soon have a new number.
        • Sheldon S.
          • March 1, 1999
          • 478
          Clark,
          I painted my 71 frame with ppg epoxy primer and then used the Eastwood Chassis paint on next. I don't remember a drying time problem. I painted both primer and paint all in one day. The primer was I think the DP90 PPG which is also black so if you scratch the paint it is black underneath. Worked good for me. I know some people just use the DP90 primer as there only paint as it looks good as well.
          Sheldon
          • Pete B.
            • February 22, 2007
            • 325
            I did my 71's frame with Eastwoods chassis black.
            Great stuff dried in less than a day and holds up great. Much more durable than I anticipated (did not scratch much during the reassembly)
            Pete Bergmann
            2005 - 2013 C6 National Teamleader
            • Clark E.
              • March 1, 1991
              • 163
              Thanks Pete...Did you use Eastwood's 2k Ceramic Chassis Black, Original Chassis Black or Extreme Chassis Black?...Clark
              • Clark E.
                • March 1, 1991
                • 163
                Originally posted by Sheldon Sands (31959)
                Clark,
                Sheldon
                Thanks Sheldon...Great idea to use a black primer. Did you finish with Eastwood's 2k Ceramic Chassis Black. Original Chassis Black or their Extreme Chassis Black?...Clark
                • Pete B.
                  • February 22, 2007
                  • 325
                  Original Chassis black, came out with a low gloss satin. Very nice! Good luck!
                  Pete Bergmann
                  • William M.
                    • July 31, 1993
                    • 390
                    I used Eastwood's Rust Encapsulator as the primer and their original Chassis Black Satin as the finish coat on my '73. Got no deductions on the frame at this year's National Convention judged by these two guys ...
                    So I think I did well
                    Bloomington Gold 2011
                    Corvette Magazine 9/11
                    Bloomington Gold 2013
                    Corvette Magazine 3/13
                    • Sheldon S.
                      • March 1, 1999
                      • 478
                      Clark,
                      I used the extreme chassis black on my frame. I applied two coats of the chassis black, which took two quarts, just made it. If you would like to see what it looks like I could take a couple of pictures and send to you.
                      Sheldon
                      • Tom L.
                        • October 17, 2006
                        • 1439
                        I'm new at this chassis painting but what do you use to apply these paints as they are sold in quarts and gallons? I'm making my plans to rebuild the rear suspension and detail the chassis in that area this winter. All this needs to be done with the body on as I'm only attacking the rear of the car. Thanks!!
                        • Clark E.
                          • March 1, 1991
                          • 163
                          Lynn...The finish paint I've looked at comes in quarts requiring a spray gun and some of the paints also have aerosol cans available which is a good idea for touchups and hard to reach places. The painter sand blasted the frame and is using an epoxy primer prior to the finish coat...Clark
                          • Clark E.
                            • March 1, 1991
                            • 163
                            Clark,
                            Sheldon
                            Thanks Shelton...A couple of pics would be very helpful...Clark
