I have been re-building a 57 engine for my 57 vette. I am nearing the end of this process. I bought a new upper and lower dipstick tube for the block. I have the lower tube installed okay. I went to install the curved upper tube and absolutely could not get it to insert and tried to drive it into the block. Finally in desperation I ground a little off the lower portion and finally was able to drive it into the block. I thought it was secure but after putting the exhaust manifolds on, it has become loose. If I insert the new dipstick into the tube and try to pull it out, the entire tube comes out. I have 2 questions.
1. Does anyone have any really good ideas on how to drive this tube into the block securely? (I may have to order another one).
2. Is there something I can secure the present one with? I am thinking about using locktite around the tube but wanted to see if there were any other ideas.
Thanks in advance for any help.
Ted
Ted
