C-1 Trunk Board - NCRS Discussion Boards
C-1 Trunk Board
  • Jerry C.
    • November 1, 1995
    • 741
    C-1 Trunk Board
    Is anyone making a correct 5 ply trunk board for a 1959? CC does not have them and I think Paragons are not correct. Thanks in advance.
    • 6954
    Re: C-1 Trunk Board
    Jerry, I went to a C-1 judging class last year and remember that they talked about the trunk board,and said if you can find the a piece of plywood with the correct number of knots in the board you could make your own.thats if you have one to use as a template.
    • Mike E.
      • February 28, 1975
      • 5141
      Re: C-1 Trunk Board
      That's news to me that there is a correct/non-correct number of knots--I know that correctness has to do with the number of plys(sp?) plies? as well as the correct staining method.
        • 6954
        Re: C-1 Trunk Board
        Mike, maybe I should have worked it different the plywood you buy today doesn't have as many knots as the factory boards did.
        Does this sound right to ya Mike ?
        • John T.
          NCRS Financial Officer
          • January 1, 1983
          • 292
          Re: C-1 Trunk Board
          Actually today's plywood generally has more repaired knots (cat's eyes) than original boards. An original board board usually had no such knots on the top and only one or two on the reverse.
          The other major difference between original and repo boards is the stain. Originals have a very thin stain. All the grain in the plywood is clearly visible. Repo boards are much too dark (finish too thick).
          Hope this helps.
          John
            • 6954
            Re: C-1 Trunk Board
            John, Mike, Thanks for setting me straight, I really was way off.
            • Bill M.
              • April 1, 1977
              • 1386
              Re: C-1 Trunk Board
              just FYI: My original '59 has no knots (cat's eyes) on top or bottom.
              • Troy P.
                • February 1, 1989
                • 1284
                Re: C-1 Trunk Board
                So did anyone ever find a supplier of the boards or of the correct plywood so you could make your own?
