63 P/B Booster (Service Repair Kit) - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5305
    Does anyone have the part number of the "Service Repair Kit" for a 63 P/B Booster. I just went through the shop manual as I believe I have an internal air leak in my booster and all it says is repair the booster with the service repair kit when an internal air leak is suspected.
    Or, can anyone point me in the direction of where one can be purchased.
  • Mike M.
    • May 31, 1974
    • 8389
    Re: 63 P/B Booster (Service Repair Kit)
    harry: years ago(80's) i had a similar 63 PB booster problem. no kits were readily available. i wnet junk-yarding and discovered 63 buick rivieras had similar PB boosters, got one off a cadaver and used the buick parts to rebuild mhy 63 vette PB booster. perhaps Booster Dewey, who ads in Hemmings, could supply a kit now-a-days. good luck,mike
    • Harry S.
      • July 31, 2002
      • 5305
      Thanks Mike, I'll give him a call tomorrow.
      Cheers
        • 43221
        Harry------
        No power brake booster kit was ever available from GM. Most component parts were available as separate pieces, though. For example, the diaphragm assembly, last available under GM# 5460895, was available until May, 1972 when it was discontinued without supercession. The other parts once available are long-gone, too.
