removing or installing a 1954 six cylinder engine - NCRS Discussion Boards
  • Joseph T.
    • April 30, 1976
    • 2074
    What do you attach to on the 1954 Corvette six cylinder to either remove or install the engine with an engine hoist?
    Joe
  • Mike M.
    • May 31, 1974
    • 8381
    Re: removing or installing a 1954 six cylinder engine
    fore and aft head bolts works for me.mike
      • 6940
      Joe, sometimes GM has extra threaded holes on the cylinder head which may let you thread a bolt through the chain or engine hoisting fixture.
      • Henry F.
        • April 1, 1979
        • 68
        Where's is Roy B. when you need him!
        ........Oops
        Hank Fredella
        Vice Chairman Northeast Chapter
        Charter Member (1982)
        Webmaster www.necncrs.homestead.com
        • Steven N.
          • April 30, 2002
          • 214
          I remove the thermostat housing and use one of thos those and use a bolt on the back of the head,,,,.....................steven j
          • Randy G.
            • April 1, 2006
            • 358
            I just installed mine with the transmission (cast iron powerglide) attached. I used the second to the last row of two head bolt holes to attach the chain from the hoist to in order to get the balance I wanted. Then I used a ratchet strap attached from the chain attaching point on the hoist and looped it around the tranny mount area at the back of the transmission to raise and lower the assembly as necessary to clear everything. Went in like a hot knife through butter.
            Back when I pulled the engine I was a little too leary of attaching bolts to the side of the head because the whole assembly is so heavy. I wasn't sure about the integrity of the cast iron and I don't like the idea of lifting all that weight with a couple 3/8 bolts screwed in sideways then pulling the whole thing over the hood and grill of my car. I decided to go the safe route and pull the head while it as still in the car and use head bolt holes to lift the engine. I made it easy on myself and my friends since I used the engine hoist to lift the head off after removing the head bolts, rocker assemblies and push rods, too.
            My back at age 54 is still in pretty good shape...and I'd like to keep it that way....so when I put the head back on this weekend I'll drop it on with the engine hoist, too.
            RG
            • Joseph T.
              • April 30, 1976
              • 2074
              RG
              Thanks for all the good suggestions.
              Joe
              • Chris S.
                • January 1, 2000
                • 1067
                Joe - I used the head bolts to install my engine
                1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
                Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
                1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
                1957 Corvette - FI 3 sp - Black and Silver
