1963 insulation - NCRS Discussion Boards
1963 insulation
  • Jeremy H.
    • January 1, 1999
    • 260
    1963 insulation
    Does a 63 have the upper jute firewall insulation like the 64-67 models? Im not talking about the black hardback with the plugs, but the two pieces above that. It is just plain jute that glues in.
    thanks
    Jeremy Hedges
    #31711
  • Timothy B.
    • April 30, 1983
    • 5201
    Re: 1963 insulation
    Jeremy,
    I know for a fact the early cars did not have the jute under the dash. Depending on you car serial #, I would wait and see if someone with a late 63 car reports.
    There were many changes with the 63, even the black backed insulation by the pedals is different early to late.
    • Jeremy H.
      • January 1, 1999
      • 260
      Re: 1963 insulation
      this one is a 6500 car
        Re: 1963 insulation
        Good question. The new JG sez "..very early cars may not have insulation.." Looking at the Assembly Manual, the sheet that has the dash mats (UPC 1, sheet B12.00), doesn't show the glued-on upper insulation, and that sheet shows its last change date as 5-63. Looks like no upper insulation could go FAR beyond "very early cars".
        • Stuart F.
          • August 31, 1996
          • 4676
          Re: 1963 insulation
          I don't see any on my early July build, but then I'm not sure what I'm looking for exactly. I know what the material looks like anyway and I've been under the dash as best I could many times including today. Can you tell me what teltale signs I should look for and where?
          Stu Fox
            Re: 1963 insulation
            Stu Fox
            Stu -
            The fuzzy stuff is glued to the back of the plenum panel (same panel the wiper transmissions are attached to), above the top edge of the hard-faced black dash mat; see photo below.
              • 15706
              Re: 1963 insulation
              ...not on my SWC, mid March build near sequence no. 11,000.
              • Guest
                Re: 1963 insulation
                none on my 19xxx July built Duntov car
                • Sydney G.
                  • February 1, 1994
                  • 444
                  Re: 1963 insulation
                  [quote=Timothy Barbieri (6542);512650]Jeremy,
                  Hi Tim,
                  Just curious but what is the difference between early and late insulation in '63 and do you know when the changeover occurred?
                  Syd
                  • Timothy B.
                    • April 30, 1983
                    • 5201
                    Re: 1963 insulation
                    Sydney,
                    I can't remember exactly what the difference is, the info may be in the archives if you want to check there. I will check my car to see what jogs my memory and get back to you.
                    • Joe C.
                      • April 30, 2001
                      • 126
                      Re: 1963 insulation
                      None on my 63- #9110.
                      • Harry S.
                        • July 31, 2002
                        • 5344
                        Re: 1963 insulation
                        None on 13356.
