I'm trying to install my grill bar and teeth assembly on my 1960 and I'm having real difficulty in getting the end brackets to mount. I thought that the slots in the end brackets would make it a snap. I've tried keeping the brackets loosely attached to the grill bar, but the span between the bumperette studs seem too far apart. I also tried mounting one side first, but that didn't work either. The bumperettes are already installed. Am I going about this the right way? Do I have to loosen (or remove) the bumperettes to get the grill bar to mount?
Thanks in advance for any help you can give.
