I have a '57 Vette with the original automatic transmission. The transmission leaks fluid - loosing at least a quart to the ground when it sits for a few days.
I have had the car into a shop that specializes in Vettes and is quite knowledgeable. The transmission was removed and all the mating surfaces were examined for alignment and all seals were replaced. Great attention was give to the problem and several months were devoted to an attempted fix. The transmission was not rebuilt as it was found not to need a full rebuild job.
The leaks persisted and the conclusion that was reported to me was the design of these transmissions is such that when the car sits for a period of time (several days without driving), fluid migrates to an area where it will leak out and that there is apparently not a fix for the leakage.
This sound a bit odd to me (I am not a transmission specialist and can't determine if this could be possible). Is there a transmission guy out there that can tell me if this is possible. Are there any '57 automatic Vettes (or other GM) out there that are allowed to sit for a period of time and not leak out a quart or more of fluid? It just does not seem possible that this would have been a design feature that would have been acceptable even in the 50's.
Thanks.
Charles
Thanks.
Charles
