Exhaust System Replacement - NCRS Discussion Boards
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: Exhaust System Replacement
    I just went with SS because I think some one can invent a rust spray that can be sprayed on the stainless to make it look as bad as the originals.
    Also kidding aside (or was I) exhaust systems also rust from the inside out. That is usually the case with temp & short drives.
    You will notice holes drilled in some exhaust systems that lets the water drip out.
    The aluminized can internally rust if you are doing a lot of short runs.
    DOM
      • 3416
      Hi Paul,
      Thanks very much for the comparison of the various materials, parts, and manufacturers.
      Also, thanks for explaining your thought process when judging exhaust systems relative to the JM.
