1967 Exhaust System - NCRS Discussion Boards
1967 Exhaust System
  • Gerald C.
    • June 30, 1987
    • 1299
    1967 Exhaust System
    I'm removing the 2 1/2" side pipes from my car so that I can comply with the tank sticker options.
    I'm thinking of a stainless steel system if it is not so cost prohibitive. Any ideas/thoughts on that idea and if so, where can I purchase said system.
    Thanks for your feedback.
    Jerry
    • 43247
    Re: 1967 Exhaust System
    Jerry
    Jerry------
    I'm a "stainless steel kind of guy". I like stainless steel ANYTHING. I'd rather have a stainless steel watch than a gold one. I've used stainless steel exhaust on my 1969 for years even though in California one doesn't really need it. Never a single problem, although I did have a slight fitment problem with the 2-1/2" system I recently installed (but, one can have the same problem with a standard steel or aluminized steel system). Yes, the stainless steel does discolor a bit (slight yellowing) but it does not RUST. I hate rust.
    You can obtain a stainless steel system from several companies and I don't consider them prohibitively expensive, at all. Allen's Exhaust is one good source. The Stainless Works is another. The latter uses a thinner gauge tubing than Allen's but that's not necessarily bad--it saves some weight. I like the heavier wall, though.
    • Brian M.
      • February 1, 1997
      • 1840
      I have an aluminized steel system from Allens on my car for 6 years, 2 Road Tours (1 of them Intl. plenty of wet driving and the system looks like I installed it last week.
      • Larry M.
        • January 1, 1992
        • 2701
        Unless you plan to continuously run leaded gasoline (the chlorides and bromides in leaded gas are very corrosive to steel), I would recommend an aluminized exhaust system. I think it will be easier to install, and will still be under the car when your grandkids inherit it.
        Just my opinion.
        I like stainless steel for many things, but feel an aluminized exhaust system is more than adequate for our cars.
        Larry
        • Gerald C.
          • June 30, 1987
          • 1299
          Thanks everyone for your feedback.
          Jerry
            • 43247
            Larry
            Larry------
            An aluminized steel system IS more than adequate for Corvettes. No doubt about it. However, there's nothing like stainless steel. By the way, a complete stainless steel system is supplied as factory original on Rolls-Royce cars (as well as many other cars).
