Turn singal dash light - NCRS Discussion Boards
  • Craig F.
    • March 1, 1986
    • 55
    Here is a strange electrical problem. In my 65 when I turn on the parking lights, the right interior turn signal indicator stays on solid and does not blink. When you then turn on the headlights, it goes off. This is strange because I have not changed one thing with any of the wiring with the car. It just started doing this on its own.
  • Paul Y.
    • September 30, 1982
    • 570
    Re: Turn singal dash light
    I suggest testing the turn signal switch. John H has made good posts in the past regarding the testing of it.
    It's a good life!
    • Joe R.
      • May 31, 2006
      • 1822
      Craig,
      That sounds like it could be a bad ground to me.
      Joe
        • 6948
        Craig, I think Joe has you on the right track, check the bulbs and make sure there the same brightness. when there is a bad ground on park lamps voltage tends to feed back to the turn indicator.
