69 Smog Pump - NCRS Discussion Boards
69 Smog Pump
  • Jim M.
    • February 23, 2009
    • 233
    69 Smog Pump
    Is the smog pump for a small block 69 Chev pickup pretty much the same as the one originally installed on a SB 69 vette?
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 69 Smog Pump
    Jim, not a answer to your question, however I bought a rebuilt replacement smog pump for my original owner 68 from Auto Zone. It has a black filter instead of one like my well used white one on the original smog pump and was a perfect replacement otherwise.
      • 15631
      Re: 69 Smog Pump
      Yes, I believe the pump itself is the same, however, the diverter valve -- which is bolted to the pump output will most likely be different.
        • 43273
        Re: 69 Smog Pump
        Jim-----
        Exactly the same pump, GM #7803948, was used for all 1969 Chevrolet applications except L-88/ZL-1. The latter used the 1968 style pump with external relief valve.
        • Jim M.
          • February 23, 2009
          • 233
          Re: 69 Smog Pump
          Thanks everyone for the quick response. jim
