Bad Battery or Bad Battery Disconnect? - NCRS Discussion Boards
  • Clark K.
    • January 12, 2009
    • 536
    My '65 Sting Ray is dead. Well, the engine will not turn over. When I open the door, the dome light does not illuminate. It could be that the old battery finally died. But, in checking the battery disconnect knob, it felt different somehow when I loosened it and then retightened it.
    Has anyone had any problem with these knob-style battery disconnect switches? Here is a photo of the type I have:
  • John M.
    • August 31, 2003
    • 167
    Re: Bad Battery or Bad Battery Disconnect?
    Originally posted by Clark Kirby (49862)
    My '65 Sting Ray is dead. Well, the engine will not turn over. When I open the door, the dome light does not illuminate. It could be that the old battery finally died. But, in checking the battery disconnect knob, it felt different somehow when I loosened it and then re-tightened it.
    I had a problem with the knob style - the standard arcing had burned through the brass plating and exposed the pot metal.
    My symptoms on my 1985 were a failure to consistently shift into overdrive, followed by a sudden stall at a stoplight about five minutes later. I managed to get it going again and made it home - I have since switched to the knife-edged type.
    • Joe R.
      • May 31, 2006
      • 1822
      Clark,
      What is your battery voltage? Did you try connecting directly to the battery (losing the disconnect switch in the process)?
      Joe
      • Kenneth B.
        • August 31, 1984
        • 2091
        I took all of them off my Corvettes. Now I just loosen the termenal cable. no problem. Theu should have made better than plated pot metal.
        KEN
        • Ed D.
          • December 1, 2003
          • 207
          The green knob disconnects only seem to last about two years! I replaced mine yesterday... same problem I buy them two at a time.
          • Joel T.
            • April 30, 2005
            • 765
            Originally posted by Joe Raine (45823)
            Clark,
            Joe
            Dittos on what is the battery voltage and if low, have you tried charging it?
            Joel
            • Jack H.
              • April 1, 1990
              • 9906
              The same mfgr makes a knife switch alternative for a few $$$ more. It's switch contacts are brass and SOLID.
              The potential reliability issues with the Green Knob version of the switch have LONG been discussed and commented on in prior posts (see archives). Personally, I've known 2-3 club members who almost 'bought the ranch' when this switch failed while they were on the road, at speed, and electrical arcing raised the switch contact resistance to the point the engine 'died' on them...
              • John M.
                • August 31, 2003
                • 167
                Thinking a little out of the box here - why don't we just require the knife blade switch? That way, newbies wouldn't have to learn the same hard won lesson over and over again...
                • Jack H.
                  • April 1, 1990
                  • 9906
                  Three reasons:
                  (1) If used 'properly' the green knob switch works! What's it take to use it properly? Well, there's no tactile feedback to indicate when the switch is closed, so some get in a hurry, screw the knob until there's a spark of life in the electrical system and let it go there.
                  What causes the arcing, is looseness. IF the knob is screwed down GORILLA TIGHT, the contact surfaces will not move relative to each other, create arcing, and contact deterioration. So, if one is properly 'schooled' in the use of the switch, it works OK...
                  (2) I've seen one club member 'modify' the green knob switch to make it bullet proof. He went to a hardware store and bought a BRASS washer large enough to make contact and overlap the knob. Then, he silver soldered the brass washer to the switch contact bar giving it a SOLID, anti-arcing, construction profile.
                  (3) NCRS doesn't dictate how you do this/that function. That a creativity killer approach.
                  • John M.
                    • August 31, 2003
                    • 167
                    Three reasons:
                    Jack,
                    Good points, though I'll say that you should have been there on that late August afternoon when my beautifully prepared, going for it's 97% 1985 decided to keel over (and you might not have wanted to explain this to my wife).
                    It sounds like there might be an opportunity out there for someone to make a properly over-engineered knob switch. Until that happens, I'll be telling our newbies (I'm teaching a Flight Judging for First Timers class next week) to buy the knife blade switches.
                      • May 31, 2002
                      • 169
                      DITTO, DITTO, DITTO. As a newbie of about 6 years, I started with the
                      crappy knob, now use the blade switch past three years. Love it.
                      • Roger O.
                        • September 7, 2009
                        • 209
                        The only problem I've seen with them is the 2 halves separate due to the heavy battery cable which allows them to reconnect,the person then loosens the knob a little more,and then a little more. When the knob is turned back in the 2 pieces are not parallel any more and the threads get crossed,then the connection is poor from there on out until failure.
                        Putting 2 plastic zip ties around the 2 pieces fixes the problem. 1/8 of a turn is all that is needed to disconnect so the threads never get crossed.
                        I had one guy that didn't like the zip ties so I drilled 2 holes through and used plastic bolts and nuts.
                        I posted some pics of the ties installed awhile back.
                        • Jim T.
                          • March 1, 1993
                          • 5351
                          KEN
                          Ken with my 68 and 70 I disconnect the NEG cable at the frame location. 5/8 ratchet wrench, it takes less than an minute to disconnect and reconnect. Lot easier than moving the seat back and going into the battery box to do the same thing. My 85 and 96 I just use a 5/16 ratchet wrench on the battery NEG cable, have to raise the hood so it takes a few more seconds.
                            • May 31, 2002
                            • 169
                            GUYS, just buy the blade switch and get over it.
                            The knob switch is a pain in the &*#@.
