76 Tilt/Tele - NCRS Discussion Boards
76 Tilt/Tele
  • Paul Y.
    • September 30, 1982
    • 570
    76 Tilt/Tele
    Is this column the same as a 1971? If so, is something different needed for the 71 steering wheel? Thanks in advance. Paul
    It's a good life!
  • Paul Y.
    • 570
    Re: 76 Tilt/Tele
    Thank you Jim Shea. I was able to determine the column had collapsed from reading your papers and getting the measurements.
    It's a good life!
    • Jim S.
      • August 31, 2001
      • 730
      Re: 76 Tilt/Tele
      This is the address for a paper on what parts are required to install a 1969-75 steering wheel onto a 1976 T&T steering column.
      Basically the actual T&T steering column (the part that Saginaw Steering Gear manufactured) is the same 1969-76. The steering wheel, telescope lock, and horn parts (supplied by Chevrolet) were different.
      Jim
      • Paul Y.
        • 570
        Re: 76 Tilt/Tele
        Thank you Jim. That is exactly what I was looking for. Paul
        It's a good life!
