1967 427 water pump bolts - NCRS Discussion Boards
  • Keith G.
    • October 31, 2006
    • 316
    Do they use lock washers?
  • Michael G.
    • January 1, 1997
    • 1251
    Re: 1967 427 water pump bolts
    Keith,
    Refer to your assembly manual but believe they do. Manual will confirm either way.
    • Ronald L.
      • October 18, 2009
      • 3248
      Appears they do - but would not be in the asy manual.
      Hopefully someone with detailed Tonawanda info can chime in.
      • Mike M.
        Director Region V
        • August 31, 1994
        • 1463
        The water pump was on the engine as assembled and painted at Tonawanda, arriving at STL as part of the engine assembly, therefore would not appear in the AIM.
        Your '67 427 did not have lock washers.
        The upper passenger side bolt also had a stud with the hex painted engine orange and the threads left bare.
        HaND
        • Ronald L.
          • October 18, 2009
          • 3248
          Mike - 66 were the same?
          • Rich P.
            • January 12, 2009
            • 1361
            I know no 65-69 did not use lock washers and I'm pretty sure the same applies up to 74.
            Rich
            • Mike M.
              Director Region V
              • August 31, 1994
              • 1463
              Yes, Ron. '66 was the same as '67.
              HaND
                • 43221
                Rich
                Rich------
                I don't think that any Chevrolet V-8 ever used lockwashers between the bolt head and the waterpump casting. Lockwashers were used between the bolt head and an alternator or other brace when it was attached by a waterpump bolt, though. Also, lockwashers were used on the outboard side of studs sometimes used in place of waterpump bolts in order to attach braces, etc.
                • Rich P.
                  • January 12, 2009
                  • 1361
                  Rich------
                  Joe,
                  Thats my experiance also small blocks included. Maybe they figured the sealant on the threads of the bolts would keep them from backing out sorta like loctite.
                  Rich
