What came first on engine Blackout - NCRS Discussion Boards
  • Kenneth T.
    • March 23, 2008
    • 631
    Having rubbed through some areas of the firewall during a clean up, I see traces of the color of the car. Was the body painted first and then blacked out?
    This is a 71.
    Re: What came first on engine Blackout
    This is a 71.
    Ken -
    Yes. The engine compartment blackout operation was performed last, after the color coat was sprayed and baked.
      • 3415
      Hi Ken,
      Here's a couple of pictures illustrating John's black-out sequence, and also what you're finding. This was an original paint car
      I started wiping the black-out with a rag that had some lacquer thinner on it and the red appeared.
      I retrieved these pictures from an earlier post
      • Kenneth T.
        • March 23, 2008
        • 631
        Hi John, Allen:
        Thanks for the replies. Allen your pictures illustrate what John stated very clearly. I have posted a picture of what I was referring to.
        I am not sure if I should try to paint it or just leave it as it is. I lean toward leaving it alone. I don't even know if it is considered during judging?
        Condition points perhaps?
        Thank you both.
        Ken
          • 11643
          Hi John, Allen:
          Thank you both.
          Ken
          It's normal.
            • 3415
            Hi Ken,
            I agree with Patrick that the thin black-out is pretty typical.
            Here's a picture I took at this year's Convention that shows the body color coming through in the same general area of the firewall on this car, as your picture.
            I would leave it as it is.
