'72 LS-5 dipstick tube finish? - NCRS Discussion Boards
  • Tom L.
    • October 17, 2006
    • 1439
    I just recieved a new (repro) dipstick tube and was wondering about the finish. It is shiny and "silvery". It appears to be zinc plated. Is this correct or should it be raw bare steel?
    Also, What about the dipstick tube handle?
    Thanks!
    • 6950
    Re: '72 LS-5 dipstick tube finish?
    Lynn, the original tubes were tin plated, not painted and the dip stick was natural 72 big blocks had a red tip on end of handle.
      • 15616
      Ironically I believe that is what the TIM&JG says. HHHMMM!!!
      BTW: If you want to tart up your engine compartment a bit you can rub the tin plating off without too much trouble. In the cases I have seen you will find copper plating underneath. That copper stick makes a striking contrast to the rest of the engine accouterments.
      • Tom L.
        • October 17, 2006
        • 1439
        Seems I read too fast. I got home and had to leave right away but had to open my box of new toys and look before I left. I was pretty sure that the tube was supopsed to be natural. I guess "Knowing" something before a little research can scew reality. Thanks anyway!!
