1966 427/425 Casting Dates - NCRS Discussion Boards
  • David J.
    • August 19, 2007
    • 65
    While looking for a 427/425 engine for my '66 convertible, all of the engines that I have located have casting dates in September or Feb/March. Is it possible that the blocks were not cast throughout the production year and only at the beginning and middle? Dave
  • Mike M.
    • May 31, 1974
    • 8405
    Re: 1966 427/425 Casting Dates
    our 66 427/425 cast date is jan 22, 66. mike
    • David J.
      • August 19, 2007
      • 65
      Thanks, Mike, that answers my question. Dave
      • Pancho T.
        • July 31, 1993
        • 238
        what date do you need?
        • Ronald L.
          • October 18, 2009
          • 3248
          Mike, Dave needs to make the relation to vehicle build date, memory says your car was March or April 66, correct?
          • David J.
            • August 19, 2007
            • 65
            Pancho, Ron is correct. I have a car built in mid-February and am trying to locate an L72, 427/425 engine. I have found engines built in Sept. and Feb./March but not with a date more compatible with the build date of my car. I am aware of the 6 month thinking used by NCRS, but Sept. is a bit on the outside of that. Beggars can't be choosers at this point, but I am trying to find the best possible engine compatibility. Dave
            • Pancho T.
              • July 31, 1993
              • 238
              Dave,I have a few let me check and see what dates I have in the building
              Pancho
              • Mike M.
                • May 31, 1974
                • 8405
                vin of 66 coupe, an ao smithy, is 18057. trim plate h 22(march 22, 1966). cast date A 22 6. machine assy stamping T0323IP . dist 6 b 14. carb stamp date 632. alternator 5L8. trans 6S118057. rear FB 3 17 66.
                • Ronald L.
                  • October 18, 2009
                  • 3248
                  Hi Mike,
                  These dates are just what I expected to see for end of 1st qtr ~ 2nd qtr production, 1966 Big Blocks. Very little time from Tonawanda to St Louis.
                  Dave, as suggested, need to get data for Jan Feb BB cars.
                  My Dec 13 trim 70xx VIN had Sept castings for all motor parts within three weeks, but I no longer have the specifics, they went with the car a very long time ago.
