I am doing a frame up on my 67 435/427 and in the 70's I had A/C installed at the dealer ( I was the installer) while the frame was being worked on.
The firewall and all the rest came out undetectable but when it came to the battery I modified the battery box and installed it to fit on the left side crossways, not length wise like the stock position. It actually worked fine that way except for the clutch pushrod, it was the only thing in the way, but the battery came out with out a problem. No power brakes either to get in the way.
I have the stock box in place in the correct location now and have to add the battery acsess panel to the left wheel well. I was going to order it from LIcorvette and asked if the panel came with a template as to where it go's and they said there are marks on the fender liner as to where to drill.
I have the old fender liner and new one that I installed in the 70's and can't see any indication on either part as to where a undrilled hole would be. I do see the hump molded for the panel on both pieces. the pieces are very clean and I don't see a trace of a undrilled hole.
Can I get a template or do I need the AIM?
DOM
DOM
