Inside door paint? - NCRS Discussion Boards
Inside door paint?
  • Rich G.
    • January 9, 2009
    • 51
    Inside door paint?
    On the inside top front corner of the door on a 72 ((by the hinge cover), there is a small corner section where the door panel ends. Is that painted the body color or is it blacked out. I'm getting ready to paint the jams and mine is blacked out but I can see it is blue underneath. Which is correct? Thanks
  • Ralph S.
    • February 1, 1985
    • 935
    Re: Inside door paint?
    Blacked out is correct
    • James W.
      • December 1, 1986
      • 278
      I've seen varying degrees of blackout there. My 71 had the entire corner blacked out, while I've seen some that had much less. If I can find the picture I took of my 71 I'll post it this evening
      Jim
        • 11692
        Follow the link in my signature below. Pelnty of pictures of this area for you to see.
        Patrick
        • Rich G.
          • January 9, 2009
          • 51
          That's how mine looked on your yellow one. I wasn't sure if that's the way it was supposed to be. Lot of good pics there. I be checking these out again I'm sure. Thanks.
